V6 T5 and V8 T5 Identification
Old Jun 2, 2006 | 02:02 PM
crazyn8's Avatar
Car: 55 Chevy (the only one that counts), 80 TA, 85 TA, 87 FB
Engine: BBC, BBC, SBC, none
Transmission: M-22, TH400, TH350, none
Tried to search but the site search feature is currently not working. I know there is a difference between the v8 and v6 t5, and believe that you can tell by the input shaft spline number. I need to know which trans has which spline number. Thanks.
Old Jun 2, 2006 | 02:22 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
v6 trans has 14 spline
Old Jun 2, 2006 | 08:12 PM
3rdgenstm's Avatar
Car: ‘92 Z28
so, a six slug t5 won't work in a v8 car?
Old Jun 7, 2006 | 12:46 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
It will work, you will have to change the clutch disc to a V6 14 spline or get a custom 14 spline 10.4 disc. also you will need to cut off about 1/2 inch of the tip of the input shaft. I ran a v6 wct5 out of a 92 camaro for about a year in my 87 GTA after the NWC t5 broke with no problems.
Old Jun 8, 2006 | 04:20 PM
crazyn8's Avatar
thanks
Old Jun 19, 2006 | 03:10 AM
Pat Hall's Avatar
V8 T5=26 spline input shaft.
