is this normal for a transmission in OD
Old Jun 3, 2006 | 04:55 PM
sting's Avatar
Car: '87 TransAM
Axle/Gears: 10 bolt 3.23
I'm not an expert on how exactly transmissions work or how ones in our cars are supposed to work, or if this has to do with the torque converter or if mine's even working (i've tried the step on the brake while cruising with foot on gas trick, but rpm does not change)
For example, in any other gear aside from OD, you'll be driving, youll let off the gas, you feel the car slow down. Once I'm in overdrive, I can let off the gas and the car still kind of "goes" to a certain point, it still slows down a little bit, but when I'm coming up to a red light, if I want to cruise and slowly slow down coming to the light (without braking), I have to shift out of OD to feel her slow down, unless im already doing 40mphish, then she downshifts at about 36-37 (number could be off since I hear digital dash's aren't accurate). She usually shifts into OD 40-45 and out around 36-37. When I got her someone kicked the idle rpm up pretty high, like 800rpm.. and she would actually stay at a steady speed (and even speed up 1-2MPH) while in OD and the foot is off the gas. Right now the idle is at 500ish.
'87 TA 305 TPI 700R4 (car has 200k miles on it, not sure about tranny)
Old Jun 3, 2006 | 05:05 PM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
Sounds normal to me.
Old Jun 5, 2006 | 11:32 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's an overrun clutch that lets the transmission coast with no engine braking when the selector is in O/D.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Stroopwafel
Sep 11, 2015 06:38 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
