T56 swappers, ground clearance to the crossmember,or lowest point of swap??
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Anyone that has made a T56 swap crossmember themselves or used aftermarket crossmembers,what is your ground clearance like to the crossmember,or lowest point of swap???Stock ride height,lowered,etc?Pics at ride height?
I finished up my T56 swap crossmember last weekend and putting the car back on its wheels I end up with 3" of ground clearance!! Now this is with small tires on junk rims that the car sits on in the winters, IIRC they are 205/65-15.The car has Hotchkis Sport lowering springs (1" drop)The tires are only about 24" tall so hopefully with a stock sized (245/50-16) I will gain alot!! The lowest point is only 3/4" under the trans mount.I tucked it up as tight as I could.Aside from this point on mine,everything else on the crossmember is level with the frame or higher in the tunnel,to help clear exhuast when I get to it.
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
I have the new skulte one.....Ill measure it and post result...pretty sure theres more than 3" of clearance.
I have the Spohn one... the driveshaft loop part is pretty low, maybe 4-5"; the crossmember is more like 6-6½".
1992 Trans Am
Aug 8, 2015 08:16 PM
