Rear End Rebuild?
Old Jun 19, 2006 | 06:23 PM
chevy_camaro_ss's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 posi
Rear End Rebuild?
I had a guy rebuild my rear end but when I looked at it when it was done it the posi unit was covered in brand new black grease. Is that normal or will it affect any. Now I know it needs gear oil after I put the cover back on but what about the grease?
Old Jun 19, 2006 | 09:31 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
He might have used the grease to determine the contact patch. I don't why black but it shouldn't hurt anything. Once the rear is on the road, the grease will mix with the gear oil and all will be well.
Old Jun 20, 2006 | 11:14 AM
Car: 1989 Camaro RS
For the contact path he used the stuff provided with the new gears I bought but it was yellow. Anyways, I just want to make sure the grease would not affect it any because this the first time I've heard or seen something like that.
Old Jun 20, 2006 | 12:46 PM
Shagwell's Avatar
Car: projects.......
many places use grease during assembly to insure initial lubrication. Until those parts have been in fluid and the pores have soaked up some lube, its a good idea. - basically the same as installing a cam.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
