How much stall do I need?
Old Jul 2, 2006 | 12:59 AM
jonarotz's Avatar
Car: 91 Z28
How much stall should I get with the new convertor? BTW I am using a
700R4.
Here are the cam specs:
Duration @ .050
Intake Exhaust
230 236
Lift
Intake Exhaust
.510 .520
LSA
114
Notes:
4 degrees advance ground into cam
Intake centerline is at 110 deg.
I will be running a Holley Stealth ram with ported out 113 vette heads and 3.73's in the rear.
Old Jul 2, 2006 | 01:52 AM
86t/a owner's Avatar
Car: 86 t/a
Engine: 383 sbc on nitrous
Transmission: Th350 with trans brake
Axle/Gears: 9in ford
there is more then that to come up with the best stall for you, i would call around to some of the companys and talk to them see what they think would work best, cant beat advice from the people that make them, also call more then one.
Old Jul 2, 2006 | 01:55 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i say 3-3.5k
Old Jul 3, 2006 | 01:18 PM
Shagwell's Avatar
Car: projects.......
the best advice you can get would be from calling a converter company. - Stay away from the cheapies for a 700r4. - If you can't afford to do it right the first time can you afford to do it again?
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
