torque coverter help
Old Jul 6, 2006 | 12:26 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
im getting my tranny rebult soon with a shift kit and a torque converter i was wondering wut torque conveter is good for a stock 305 carb 2 get my tires spinning but im planing 2 put a cam,headers, heads, lifters,etc.. so far i got 3.5 in flowmaster cat back with 4 in tips took all emissions off and minor shyt
Old Jul 6, 2006 | 12:31 PM
Shagwell's Avatar
Car: projects.......
there are WAY to many variables in what you have/are gonna have to even attempt to spec a converter. - Stay away from the TCI, B&M, and all the cheapies for a 700r. - If you can't afford to do it right the first time, can you afford to do it again?
Old Jul 6, 2006 | 01:56 PM
xgtharo86x's Avatar
Car: 86' Trans am
wuts a good stall for a stock 305 ill change it when i get all my othere stuff
Old Jul 6, 2006 | 02:56 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
What is wrong with the TCI and B&M converters? Is it one particular model that you had trouble with, or are you suggesting that there entire line of converters are junk?
I was about to buy a B&M Holeshot, are you saying that it is junk?
Old Jul 6, 2006 | 09:16 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
If he won't say it, I will. all B&M Converters are junk. There, I said it. I've posted before about why I believe that. Get an Edge EDGE Racing Converters | Welcome Andre at Edge is one of THE BEST converter guys on teh planet. one of his converters will net you .4-.5 seconds in the 1/4 over a B&M and will be 100% streetable without generating excess heat. "You get what you pay for" is especially true with torque converters.
xgtharo86x, for your application, since you're so stock, the stock S-10 converter might be a good choice. It stalls around 2200 RPM, and is pretty cheap($120ish from most parts places). Searching will give you the S-10 year range your after.
Old Jul 6, 2006 | 09:25 PM
xgtharo86x's Avatar
Car: 86' Trans am
thanks
Old Jul 7, 2006 | 01:25 PM
Shagwell's Avatar
- My 13.90 4.3 S10 Blazer took a "holeshot" out on its 4th pass. - B&M and TCI use stock cores and loosen them up. You end up with a converter that stall higher, but the fins can flex/bend/tear out, they generate more heat, and less driveability. Every one I've ever seen in a 700r only lasted about 10k, then took the trans out with it.
- You deffinitely get what you pay for. Cheapy converters are just that. - For a stock/mild combo, the "B29X" (4.3 stocker) is the way to go. Cheap, effective, no issues.
- past that, edge, yank, precision, ati, raptor(patc), or torco for a 700r converter.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
