700r4 TailShaft bearing
Old Jul 20, 2006 | 09:32 PM
83Chevy_Camaro's Avatar
Car: 1988 Camaro
Engine: 1988 chevy pickup 350 TBI (rebuilt)
Transmission: 700r4- Bowtie overdrives
Axle/Gears: 2:73's
My yoke that slips onto the output shaft on the transmission wobbles up and down, side to side.. U-joints are fine, The tailshaft seal doesnt leak.. Just quite a bit of play on that output shaft.. I had a brand new tranny installed about 1500 miles ago.... I am not sure if theres a bearing in the tailshaft or not..
Thanks for any help, Nick
Old Jul 21, 2006 | 06:12 AM
No bearing, just a bushing.
It can be changed while the trans is assembled and installed, with the right tools. Call around to transmission shops in your area, and find someone that has those tools. The puller looks sort of like a gear puller, except the teeth point outwards, and they're real thin. The installer looks like a piece of pipe.
Last time I had that done (no I don't have the tools ), I paid $25, and it took less than 10 minutes from drive-in to drive-out.
Old Jul 23, 2006 | 06:18 PM
jr. gearhead's Avatar
Car: 83 T-Top w/ 85 Z-28 and 91 RS parts
Engine: 377 (in progress)
Transmission: 700-R4 (unless i find a t-56)
Axle/Gears: from the Z
if you take the tailhousing off, the same piece of pipe and/or socket will serve to remove and install the new one. just make a note of the installed depth and set it the same for the new one.
Old Jul 23, 2006 | 06:33 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Remove the driveshaft and wiggle the output shaft on the trans by hand. If it moves alot, the case bushing is worn out or has spun. Alot of guys do not change the case bushing during an overhaul.
Old Jul 23, 2006 | 06:38 PM
its normal for the output shaft to wiggle a little bit when the driveshaft is out...the bushings are the only things the entire gear train rides on! the tail bushing is VERY often overlooked (read: ignored) during rebuilds. i have seen quite a few that make me wonder why the driveshaft is even able to turn.
Old Jul 25, 2006 | 05:05 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
The driveshaft is hooked up and it still wobbles... The warranty for the tranny is still Good.. and i had a chevrolet dealer install it so, i guess, i shall make a phone call tomarrow, since they are closed now...
Thanks Alot guys! I was going to ignore it because the tranny is like a month old, and has less than 2,000 miles on it.. i figured it was normal, but i thought id ask.. Good thing i did!
Thanks Again, Nick Hall
loud91rs
Oct 5, 2015 10:05 PM
gord327
Oct 3, 2015 01:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
