Transmission Slips
Old Jul 30, 2006 | 10:34 PM
Lewism111's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
Transmission Slips
Could this be why my tranny slips?
THE AUTOMATIC TRANSMISSION SHIFT CONTROL CABLE CAN SEPARATE.Consequence Summary:SEPARATION OF THE TRANSMISSION SHIFT CABLE CAN PREVENTTHE TRANSMISSION FROM BEING SHIFTED INTO THE PROPER POSITION. THIS CONDITION CANCAUSE UNEXPECTED VEHICLE MOVEMENT WHEN THE TRANSIMISSION INDICATOR IS IN PARK ORNEUTRAL POSITION AND THE TRANSMISSION IS IN A DRIVE MODE; THIS COULD RESULT INA VEHICLE CRASH WITHOUT PRIOR WARNING.Corrective Summary:THE DEALER WILL REPLACE THE SHIFT CABLE.
Old Jul 31, 2006 | 05:25 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
not likely. if your tranny is slipping, check your fluid level and your tv cable adjustment. if they are good, the problem is internal and will need servicing soon the shift cable doesn't have a lot to do with shift characteristics. if your tranny is engaging in forward, reverse, neutral, and park good, then it isn't your shift cable.
Old Jul 31, 2006 | 12:32 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
Agreed. That shift cable problem is more for when you are not moving. Like when you think you put it in park, but really it's still in reverse.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
camaronils
Sep 20, 2015 02:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
