What else do I need? (T56 from 700R4)
Click the picture above!!!
So here's what I've got so far. Nice shifter plate, some 01 TA Pedals, and I've got a picture of a 93-97 Camaro Hydraulic master/slave setup.
My question is...
This should work with the 01 pedals right?
Also, I should only get this hydraulic setup if I obtain a 94-97 T56, correct?
Has anyone tried the RETROFIT T56 from Sallys? Since I'm using a mechanical speedo I thought this might be a good idea, but the price is aweful high, and I'm not too fond of cutting the shaft / torque arm.
Assuming I obtain a 94-97 T56 (my local tranny shop said they can get me a remanned one for 1700 with 2yr warranty, and they will buy my old 700r4), what else will I need?
I may have the tranny shop do the tranny install (they are very interested in seeing my project come to life and will discount me, great guys) but I want to do as much work as possible...
I will hook up the pedal assembly and clutch master/slave assembly, and dismantle the console. I can't exactly cut the hole as I need to be able to drive this to them (1/4 mile away).
With that done, all the tranny shop would have to do is:
1. Remove the transmission.
2. Slap on new flywheel/clutch/etc
3. Bellhousing... (since I'm using a 305 Carb'ed, which bellhousing should I search for, assuming I go with a 94-97 T56)
4. Bolt up the tranny and finally the switches. (assuming I'm using a 94-97 T56, should I get a flywheel/clutch that is designed for a 94-97 Camaro?)
I'm sure there's more but thanks in advance!
Regards,
atvance
You need the bell housing that comes with the 94-97 T-56. No other will work.
The 94-97 flywheel will not work. It is for a 1-piece rear main seal motor, but you have a 2-piece rear main seal motor; the bolt pattern on the back of the crank is different. There is no stock flywheel that will work, it simply doesn't exist. You need a special "conversion" flywheel. The usual one is the Centerforce 700107.
You need a different crossmember, as the T-56 one is farther toward the rear of th ecar. Again, no stck one will work; but there are a number of them that you can buy that are made for that, including from some of the board sponsors. I have the Spohn one, along with his torque arm; that combination relocates the torque arm mount point off of the trans, and to the crossmember directly.
The T-56 will not accomodate a cable speedo, as it sits. The hole in it for the VSS is directly in line witht he center of the mainshaft, not offset below it like a cable setup needs to be. The way to solve this is either by modifying the housing, or by using what amounts to a little electric motor that takes in pulses from the existing VSS and spins the cable for you. Look here for info regarding the former, or here for the latter.
Read this thread. https://www.thirdgen.org/forums/faq-...questions.html All of it.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
