wont shift out of 1st
Car: 88 iroc
Engine: 5.7 350TPI
Axle/Gears: 373'S
I just dropped in my motor yesterday after I rebuilt it. everything is hooked back up but I see 4 wires that looked like they got ripped out of a clip just laying there. I am not sure where they go. On the drivers side of my 700r4 there is a clip. there are no wires going to it though. It has 4 prongs though. I know it had an aftermarket 700r4 put it in b4 I got the car. Is there anything electrical that tells it when to shift. Is it something that has to do with vacuum? If it is electrical, how do I know which order the wires go into this clip?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's the wiring for the torque converter clutch. You'll need to do something with it, but it's not causing your problem.
Did you connect the TV cable?
Car: 88 iroc
Engine: 5.7 350TPI
Axle/Gears: 373'S
yes i did. I really need help here guys. I am stationed here in germany so I have no where to go. There is the first car show since I've been here in about 12 hours and I would love to show my car off, but I dont know what to do. My fluid is perfect. my cable is connected and I even redlined it trying to get it to shift, but nothing is working. It was all good before I pulled the motor.
darwinprice
17
Oct 11, 2015 11:51 PM
