t5
Old Aug 15, 2006 | 08:28 PM
don71's Avatar
Car: 1992 rs
Engine: stock 305 tbi
Transmission: t5
Axle/Gears: 3.42 10 bolt
t5
what are the possible things that cause a t5 to pop out of fifth gear come on guys any body have any idea
Old Aug 17, 2006 | 09:51 AM
drag1LE's Avatar
Car: 1991 Camaro 1LE Z28
Engine: 6.0L
Axle/Gears: Ford 9" 4.33
Do you have an aftermarket shifter?
Old Aug 17, 2006 | 10:12 PM
don71's Avatar
Car: 1992 rs
Transmission: t5
no it had a stock one it is out of a different car guy told me it popped out of fifth gear sometimes
Old Aug 18, 2006 | 10:31 AM
drag1LE's Avatar
Engine: 6.0L
What do you mean by "stock one out of a different car?"
A stock shifter, but not the one that came with the car?
or
You're asking this question for someone else's car (and not your own)?
Old Aug 19, 2006 | 11:46 AM
don71's Avatar
Car: 1992 rs
Transmission: t5
sorry bout that it a stock shifter on a trans i am getting was wondering what could cause it to pop out of fifth gear the guy told me it did this sometimes
Old Aug 19, 2006 | 12:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Worn out synchro maybe.
Old Aug 21, 2006 | 09:17 AM
drag1LE's Avatar
Engine: 6.0L
Worn out synchro is one way to go.
The reason I was asking about the shifter is that this has happened to me, but only because the stops on my shifter weren't adjusted properly (aftermarket shifter). Obviously not the case with your issue.
