silly question
Old Aug 25, 2006 | 11:03 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
silly question
how can i test to see if my converter is locking up
Old Aug 25, 2006 | 11:08 PM
facelessnumber's Avatar
Car: 91 RS
Engine: L03 carbed
Transmission: 700R4, rebuilt+kit
Axle/Gears: 3.42, posi, disc
On the highway, in fourth gear at a steady cruise, give it a little throttle and watch the tach. If your tach goes up before you feel the car accelerate, it's not locked. Also, give a little throttle without downshifting and watch the tach while you ever-so-slightly press the brake with your left foot. The tach should jump up a little as the converter releases.
Old Aug 25, 2006 | 11:17 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
I'm not sure about newer cars but used too, you could barely put pressure on the brake pedal and the converter would unlock due to the switch on the brake pedal and your rpm's would increase.
Old Aug 26, 2006 | 12:16 AM
Car: 87 trans am
i tried the throttle and tab the brake, no change in rpms. reason why i ask is after i let off the gas in fourth, it feels like i have engine breaking
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
