help please
Old Aug 29, 2006 | 12:35 PM
monoply6's Avatar
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
help please
hi all tried to remove steering wheel could not get it off so booked it in to the local garage but to my horror when i puled off my drive my engine died and my steering wheel broke its the metal outer casing of the ajustable arm broke all the way round and the metal rod connected to the ignition so is there any way of removing the hole colem with out removing the wheel
Old Aug 29, 2006 | 01:39 PM
Shagwell's Avatar
Car: projects.......
yes, you can pull the column without pulling the wheel. - not sure on what you're saying broke though....
Old Aug 29, 2006 | 02:56 PM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
its the metal outer cover that surounds the steering shaft that comes from the fire wall and connects to the ajustable part of the steering wheel,is it easy to remove are the bolts on the fire wall thanks
