need some torque specs...
Old Sep 26, 2006 | 12:06 AM
street_carnage's Avatar
Car: 89 GTA
Engine: 5.7L
does anyone have the torque specs for the torque arm to axle, lower control arms at axle, panhard bar, and lower shock bolts?
Old Sep 26, 2006 | 03:32 AM
ede's Avatar
ede
i either used an impact or went for real damn tight with hand tools
Old Sep 26, 2006 | 11:24 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think torque arm to axle is like 130ft/lbs
LCA's are somewhere in the 65ft/lbs range, same with panhard
shock bolts, you are compressing that rubber sleeve, so I think it'd be less.
But I usually use Ede's method too. Make sure the suspension bolts use stover nuts, not normal nuts!!!
Old Sep 26, 2006 | 01:29 PM
I tighten mine a little tighter than ede does; I usually go almost all the way up to REAL F'ING TIGHT with hand tools.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
