Speedometer questions
Old Sep 27, 2006 | 02:41 PM
ttopformula88's Avatar
Car: 1988 Formula
Axle/Gears: 3.73 Posi
Ok here it goes...
I am going to be swapping an '83 t-5 into an '88 formula. I need to know what i need to make the speedo work properly. I have 3.73 gears. What gears, connectors, etc do i need to make this work??
Old Sep 27, 2006 | 02:58 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/tran...en+gear+sleeve
JamesC
Old Sep 27, 2006 | 10:44 PM
Car: 1988 Formula
Do i need to replace both the driven and drive gears?
Old Sep 28, 2006 | 05:38 AM
JamesC's Avatar
Pop the driven gear and its sleeve and check inside the tranny (or pop the tail shaft) for the drive gear. You'll need to change the gear or gears if you don't have a 7-tooth purple (mine was more blue) drive gear and a 21-tooth red driven gear.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
AUZ28
Oct 12, 2015 08:40 AM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
redmaroz
Aug 16, 2015 11:40 PM
