9 bolt posi
Old Sep 30, 2006 | 02:22 AM
Chevyz2882's Avatar
Car: 1982 Z28
Transmission: 700-R4
9 bolt posi
Will a 9 bolt posi with 3.70 gears (disk brakes) out of an 85 camaro bolt right up to a 82 z28 with out a problem.
Old Sep 30, 2006 | 04:03 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
If you have a 9 bolt in the car already, if it's a 10 bolt then no, it's a completly different rear end.
Old Sep 30, 2006 | 04:46 AM
ede's Avatar
ede
the carriers won't interchange, the complete rear ends will
Old Sep 30, 2006 | 11:25 AM
dab2pds's Avatar
Car: 05 corolla xrs, 05 hayabusa, 91 rs
Engine: 383
Transmission: t56
the complete rear end should bolt right up. make sure u get the proportioning valve off the donor car or the brakes wont work right.
Old Oct 4, 2006 | 03:27 AM
Pat Hall's Avatar
The rearend itself is a direct bolt-in. The only thing you may have an issue with is the fact that 82's have SAE brake lines, 85's are metric, so you might have to use some adapters or change a couple of brake lines to get everything working.
Old Oct 4, 2006 | 05:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I know the 9-bolt was available in 85, but I was unaware that they saw action in Camaros.
JamesC
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
djmarch
Sep 13, 2015 01:35 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
