help before i spend some money
Old Oct 7, 2006 | 10:11 PM
cam92rs's Avatar
Car: 25th anniv. camaro
Engine: 305 tbi
will a 1989 monte carlo ss posi rear end be a easy fit in my 1992 camaro? the ss rear is not disk brakes(i dont want that) but is it near the same mounting pattern as the camaro?the reason for the swap is because i want a posi,and i dont wanna have to put gears in it or anything,it already has i htink 3.34 or something,i cant remember what he said,but then again,im not positive its a lsd either.im goin to check it out,and before i pay,i wanna know how hard it would be to put in my car.would it be worth to start out with a posi rear,get the posi rebuilt and put gears in it,or should i just start out with my open get a posi, and put gears in it?
Anthony
Old Oct 8, 2006 | 02:09 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
The housing is different and won't swap without work that is beyond most people's abilities.
The G-body housing doesn't have a torque arm mount and you would have to swap the LCA/shock/spring perches from your 10-bolt onto it too.
RedLeader289
May 28, 2019 01:47 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
