Noobie question about rear end
Old Oct 12, 2006 | 08:33 PM
drshirk's Avatar
Car: 91 Camaro RS Convertible
I have an 88 firebird formula. It has rear disc brakes. How can I tell first what rear end I have. I read that 9 bolt is a borg warner. I have a nine bolt. How can I tell what gears it has and if it is posi or not? I read to take the cover off and look but what do I look for?
Old Oct 12, 2006 | 08:48 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
numbers on the gear will say the ratio
Old Oct 13, 2006 | 05:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As xpndbl3 mentions, a number should be stamped on both the ring and pinion to provide the gear ratio:
41 : 15 = 2.73
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
If the ratio is different than your current rear end, you may need to swap the drive or driven (or both) in the tranny to get an exact speedo reading.
Posi or not?
https://www.thirdgen.org/forums/tran...what-axle.html
JamesC
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
