388 stroker with 305 flywheel and T5
Old Oct 17, 2006 | 02:15 AM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
ok did some searching and want to double check what i've discovered.
I have a 388 stroker with a 400 crank and a stock 305 flywheel and a WC T5. I'm switching from an externally balanced flexplate to this flywheel. So all I need to use this 305 flywheel on my motor is the balancing plate you can buy? Am i correct? Any help would be greatly appreciated. Thanks.
-Greg
Old Oct 29, 2006 | 10:25 PM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
TTT
Old Nov 2, 2006 | 10:20 PM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
NEbody?
Old Nov 3, 2006 | 12:01 AM
carguy502's Avatar
Car: 1969 Nova
Engine: LT4 Hot Cam L98
Axle/Gears: 3.42 8.5" 10 bolt
You probably need to be more specific. Factory or aftermarket crank? Factory was an external balance and early 305s were, too, I think. Aftermarket cranks are usually internally balanced. Probably best bet would be to contact your manufacturer of choice and ask questions based on the info you have.
Old Nov 3, 2006 | 12:28 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Right, you can can just buy a balance plate for like 15 bucks. But make sure that you need to externally balance your setup.
Old Nov 3, 2006 | 02:24 AM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
Yeah my rotating assembly is externally balanced. I have a TCI flexplate part#399373 on my automatic right now. So from what I've read so far I can either get the balance plate and offset the flywheel that way or get my flywheel "unbalanced" to match the TCI at a machine shop. Correct? Also, is the plate that bolts in between the flywheel and crank gonna mess up any clearances?
Old Nov 3, 2006 | 07:32 PM
Engine: 400
I have run the balance plate with no problems. Although a member here on the forums had some major issues with his clutch master cylindar. I think he went through 3 of them because of some clearance issue? I'm not sure. Yeah, either buy an externally balanced flywheel or slap on the balance plate. *shrug*
Stangski09
Nov 14, 2015 01:27 PM
angel2794
Sep 8, 2015 06:22 PM
FireDemonSiC
Sep 3, 2015 12:31 PM
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
