T56 Electrical Connectors
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
How many electrical connectors are on a '93 T56, and what are they? Any help will be much appreciated.
Engine: LT1; None
Ok, doesn't a '93 lack the CAGS? So that'd be three? What is their relative location (left, right, top, bottom etc.)
Thanks so far.
Thanks so far.
I don't know specifically about a 93....
The reverse light one is on the pass side (all others on the driver's side); the CAGS is on the case, in front of the flange where the extension housing bolt to it, near the top; VSS is in line with the mainshaft, toward the rear, where it sort of necks down; reverse "allow" solenoid is right next to the shifter (it blocks the shifter from going toward reverse)
1995, 95, camaro, connectins, connections, connectors, electrical, extension, shift, skip, solenoid, t56, trans, transmission, vss
