t5 swap question. need quick advice
Car: 89 GTA
Engine: 5.7L
will a world class t5 from an 88 2.8 fit into a 87 5.0 and vise versa. and if it wont is there any workarounds? i need to know quick. im sure the input splines are different but let me know.
Car: 89 GTA
Engine: 5.7L
i know pizza_guy is doing a similar swap.
putting the tranny/clutch/bellhousing from the v8 to the v6 might not be a problem
but what about putting the the stuff from the v6 to the v8?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Did you do a search? This question comes up all the time. The basic answer is no, a V6 and V8 T5 are not compatible. The long answer is you can make it work if you want to spend time and money that isnt worth it.
Hello, Michael
Aug 20, 2015 03:19 PM
