T 5 questions
Old Oct 27, 2006 | 09:47 PM
akcirocz's Avatar
Car: 1986iroc-z,2005 silverado z71
Engine: 396 tuneport
Transmission: ???
Axle/Gears: 373 ford9" detroit locker
T 5 questions
hey guys needing your help on a 700 r4 to a t5 swap in my 86 iroc.i have all the parts from a donor car.and i just bought a center force df clutch and a pro 5.0 shifter.my question is can anybody take a pic with a measing tape next to there stock hole in the fire wall so that i can drill the hole for the hydraulic rod in the correct spot..and also a pic to alighen the pedals correctly bolt for bolt to the car..i pulled all the stuff from a donor car in the local junk yard and it has since been crushed.also looking for flywheel recomendations.i have a 350 tuneport punched out to a 396 with a d1sc procharger.650 to the rear wheels.so i think im going to need a 30 or 40 pound flywheel.thanks for the help.
Old Nov 15, 2006 | 06:29 AM
The Phantom's Avatar
Just posted a pic of a conversion shifter hole, use the diamensions from the Tech article, you will have to shave back your console mount bracket. The pick can be found in post titled "RASSA FRASSA ..."
The Phantom
Old Nov 15, 2006 | 08:42 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
use the carpet map as a outline
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
