T56 Shifter
Old Nov 7, 2006 | 05:18 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
T56 Shifter
I'm looking for an aftermarket T56 shifter that will allow me to put on my own shift handle. All of the aftermarket shifter I looked at the handle can not be changed unlike the factory shifter. Anybody know of a good one?
Old Nov 7, 2006 | 08:27 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Pro 5.0
Old Nov 7, 2006 | 08:44 PM
vbMike's Avatar
Yea besides that one. It's kinda pricy.
Old Nov 7, 2006 | 08:56 PM
Stevo's Avatar
Car: Pair of 92 Z28s
that is the best they say...ill be looking into one of those in the future.
B&M, Hurst, Pro 5.0 are the top dogs and some of the only shifters pretty much.
Old Nov 8, 2006 | 02:20 PM
Zepher's Avatar
stock Hurst shifter has a removable shaft., you can probably pick one up cheap. I gave 2 of mine away a couple of years ago.
Old Nov 8, 2006 | 05:17 PM
vbMike's Avatar
Were all stock shifter made by Hurst or was that an extra option? I thought I had read somewhere that the hurst shifter was a stock shifter with a hurst handle, is that true?
Also I have a question about the shifter springs. The springs that center the shift handle, is that part of the shifter or the transmission? I noticed on the stock shifter when I push the handle left to the 1/2 position it will return the the 3/4 position if I leave it in neutral. However, when i push the handle to the 5/6 position it will stay there even though it is still in neutral. Is it supposed to do this? I figured it would always return to the 3/4 position when in neutral. Do I have a bad spring and if so is this something a new shifter would fix or does something in the tranny need fixed?
Old Nov 9, 2006 | 05:15 PM
SSP6's Avatar
Car: 89 formula/ 91 Formula
Engine: 1 355/ 1 305TBI
Transmission: 1 t56/ 1 A4
Axle/Gears: 1 4.10/ 1 3.42 both locked
i've got an SLP short throw, and a factory option Hurst, and bot use removable sticks.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
