Lock up problem? TV problem?
Old Nov 18, 2006 | 02:38 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
If I get up on my car, it will shift in 3rd and then just accelerates red line...let off the gas for a couple seconds it will then shift, then you can stomp on it again.
If you are cruising at 50 then stomp on it, just accelerates to redline and does not shift till you let off.
I just did the T-5 to auto swap.
I wired the TCC lock up according to schematics (couresty of Vader) to my ECM.
The tv cable has a small kink in it between the D button and TB. not sure if that could affect anything. But i adjusted the TV cable atleast 5 times.
Do I need a new TV cable or is there something else I am missing?
BRoss99
Aug 10, 2025 05:08 PM
someone972
Aug 30, 2015 12:52 AM
neekolzun
Aug 24, 2015 04:59 PM
CORV3TT3
Aug 23, 2015 11:26 AM
g.l.mos
Aug 22, 2015 12:02 AM
