Speedo noise
Old Nov 21, 2006 | 10:52 AM
Viking's Avatar
Car: / 89 IROC /
Speedo noise
I think I need to lubricate the speedo cable or maybe the gear in the speedo. When I get over 20 mph it starts making a dry sounding squeek that increases in frequency the faster I go.
Has anyone had this issue and what did you do to solve?
Old Nov 22, 2006 | 04:15 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
With as many miles as you have on the car, the speedo cable could easily require lubrication.
JamesC
Old Nov 22, 2006 | 04:24 PM
Viking's Avatar
Car: / 89 IROC /
This is already the 2nd speedo cable. Not looking to replace this time, that was a pain. Looking for ideas as to how to lube it.
Old Nov 22, 2006 | 04:36 PM
JamesC's Avatar
Disconnect the cable/housing from the tranny. Pull the cluster to access the cable. Pull the cable out of the housing. Flush the housing with a cleaner (I used brake cleaner) until clear. Reattach the cable/housing to the tranny. Fill your palm with Syl-Glyde (Napa) or another lube designed for speedo cables and run the cable through it and into the housing. You may have to twist the cable a bit to reseat it in the driven gear. Replace the cluster.
JamesC
Old Nov 24, 2006 | 09:16 AM
Pat Hall's Avatar
I got some dry graphite stuff that's supposed to be for lubricating speedo cables, but it doesn't seem to work very well. The stuff James suggested is probably your best bet. I need to do the same thing. Now that the weather's getting cold, I noticed my cable making the same noise as yours.
Old Nov 27, 2006 | 03:53 PM
Viking's Avatar
Car: / 89 IROC /
thanks guys - I'll dig into that over the weekend...
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
