Clutch master cyl?
Car: 85 firebird
Engine: 355 soon to be 406
Transmission: th350
Axle/Gears: Summers Bros 12 bolt 4.56
Clutch master cyl?
Im working on an 88 firebird put in a 2006 GTOLS2 and T56 6 speed I have the throwout bearing and clutch setup but does anybody know for sure what clutch master cylinder to use? Can I use the stock one ( car had a T5) I got the GTO master but I cant see a way to make it work the rod is to short to reach the pedal and its all plastic so I cant weld a longer one on.The only issue I see with the stock one is the plastic line it uses but I can convert that to a stainless flexible one.Any help would be greatly appriciated.
Steve.
Steve.
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Not realy sure how the GTO hydros work but the 93-97 lt1 cars use a stainless line that is flexable and is a few inches longer . Works just like stock hydros in third gen cars .
Car: 85 firebird
Transmission: th350
I found a guy who can make me a braided stainless line with the correct fittings so I'm going to use the stock t5 master . The cars almost done Ill let you know how it works out.
88 Firebird 06 GTO ls2 ported heads, cam, upgraded valve springs titanium retainers , pushrods F.A.S.T. intake 90mm throttle body, Moser 9" T56 trans
Spec stage 3+ clutch .Ill try to post some pics.
