transmission survival
Old Dec 20, 2006 | 10:36 PM
B&WIROC's Avatar
i dono if this is in the right place but what the heck yall got answers ( i hope) so i have a 1986 iroc z with a 700R4 transmission. i just recently had to replace it because all the gears went out except 1st. this is an automatic by the way. so i think the problem is that when i start the car and have it in park (or neutral) the motor is reving up so high it hits the gears to hard when it engages. so i need help in finding out what's making it rev so high. i was thinking throtal positioning sensor? maybe i have no clue.
Old Dec 24, 2006 | 07:18 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
What are your RPM's at in park? When it's in drive? Was it leaking at all before? Have you put a shift kit in it?
Old Dec 24, 2006 | 09:59 PM
B&WIROC's Avatar
in park or neutral the RPM's are at about 2500 (i know way to high) and then when you put it into gear it goes down to around a 1000 RPM's. it was leaking before but i have no clue where. and the knew transmission i put into it still leaks at the yoke because its old and really shity. i did have a shift kit put into it and i had all the lines replaced from plastic to metal.
Old Dec 24, 2006 | 10:09 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Id replace the yoke if its badly worn. Not too hard to do. There are alot of things that can make the car idle high. Worn throttle shaft, incorrect carb settings, vacuum leak, etc. Tech/general engine may be a better place to ask about the engine part of it.
Old Dec 24, 2006 | 11:09 PM
Pro Built Automatics's Avatar
The 1986 & earlier units did not have a forward accumulator, which softened the neutral/park to drive engagement. The high idle does not help. If you lost 2nd, 3rd, & 4th gear all at once, and now you have 1st gear only, the governor would be the first place to check for broken or stripped gear. Let me know what you find?
Old Dec 24, 2006 | 11:29 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Originally Posted by Pro Built Automatics
The 1986 units did not have a forward accumulator, which softened the neutral/park to drive engagement.
Well that would explain why mine (1984 model) shifts hard from park to drive...I've always wondered about that. It only got worse when I added the shift kit.
Old Dec 25, 2006 | 12:44 AM
B&WIROC's Avatar
so is it possible to put a forward accumulator on a 86? or would it be a lot easier to just find out what's making it happen now and fix that? also on the yoke... is this just a dealership part? i've looked around and couldn't find it. i have a mechanic friend and he told me its gonna cost me around 300$ just for the part not to mention the amount of time to put it in.. is this true?
Old Dec 25, 2006 | 12:58 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
it shouldnt be quite that bad for a yolk, even from a dealer.
Install time is very short, that is, if you have a vise. It takes about 2min to unbolt the u-joint from the pinion then pull the entire driveshaft out. About 5min in the vise and you have the front u-joint out and the new u-joint and yolk installed. slide the slip yolk into the tranny, tighten up the bolts on the pinion side u-joint and your good to go.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
64Chief
Sep 12, 2015 08:05 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
