question?
Old Dec 27, 2006 | 11:44 AM
90IROCJustin's Avatar
Car: 1988 Camaro (Z28 Clone)
Engine: 305 4bbl roch
question?
i have a queston about rear axles.... will a rear end from a 1990 IROC-Z w/ 3.23 gears fit in a 1988 IROC-Z with 2.73? how much does it cost to make the switch and do i have to modify anything?
any help would be appreciated thank you
Old Dec 27, 2006 | 12:35 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The axles will not swap from the '88 to the '90 rear end, the spline counts will be different.
The rear end from the '90 will, however, swap right over to the '88. If you're looking to swap rear ends I'd recommend, at a minimum opening the cover on the rear end and inspecting the innards (is that one "n" or two?). Make sure you don't have a gov-lock and have the ring/pinion you're expecting. Make sure the wheel seals are good, refill with new fluid and bolt it in. Swap over brake hardware if needed. Pick up the correct speedo gear and you're done.
Shouldn't cost more than around $20 for fluid, maybe some posi additive (if it's posi) and a speedo gear.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
