T5 VSS part number
Old Dec 29, 2006 | 12:17 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
can someone give me the part number for the right vss for a t-5?
Autozon only has a listing for the su1010 which i found out today that it is for the 700r4 ( was huge)
Old Dec 29, 2006 | 05:56 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Go to partsamerica.com and look under the Speed Sensor listing. It's the D9E option code, and you have to find a gear that will go with it (from an 85-up trans). Now, if only I could find out WTF is up with my wiring between the speedo and the sensor, I'd be all set...
Old Dec 29, 2006 | 09:25 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
thanks a ton, you wouldnt happen to know the numbers for gm for the speedo driven gear do you?
i think myn takes a red one
Old Dec 30, 2006 | 05:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
you wouldnt happen to know the numbers for gm for the speedo driven gear do you? i think myn takes a red one
Check the following link for part numbers:
https://www.thirdgen.org/forums/tran...en+gear+sleeve
JamesC
Old Dec 30, 2006 | 08:10 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
thanks a bunch
Are those for both a electric VSS ( d Shaped end ) And the mech sender? i have the electronic trans mounted vss i need to order and that looks like a plastic gear out of the mechnical housing
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
