Difference between an 85 and a 90 TH700?
Old Dec 31, 2006 | 07:24 AM
PerthZ28's Avatar
I know that the TH700 transmissions were upgraded around 87 but does anyone know what the differences were?
A mate of mine has a spare TH700 out of a 90 Camaro and I want to install it in my 85 Z28. Will they swap over directly? The 90 one was rebuilt [all stock] about 3 years ago - would I be better off just having mine rebuilt rather than swap in the 90 one? Its only done a couple of thousand miles since the rebuild but its been sitting around out of the car for about 6 months...
Old Dec 31, 2006 | 08:18 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The 90 has the following improvements:
10 vane pump vs the 7 vane
28 element sprag vs the 26
wide lo roller clutch vs the narrow
aux valve body
slightly deeper pan (1 mm)
Old Dec 31, 2006 | 08:19 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Everything else is physically the same.
Old Dec 31, 2006 | 11:29 AM
RacerDad916's Avatar
Car: 89 Z28
Engine: 355 full roller, Brodix 10X heads
Transmission: Close ratio Muncie
Axle/Gears: 3.42/7.5
I think the '90 has a better low gear planetary set as well.....
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
