Difficulty in converting an automatic to a manual?
Old Jan 2, 2007 | 11:14 PM
KMK454's Avatar
Car: 1991 Camaro B4C
Any idea on the cost and difficulty in converting an auto Camaro to a manual? I keep looking and everytime I find that nice, low mile 3rd Gen, sure enough it has an automatic. Ok for some, but I hate automatics! Sorry!
Can a shop do this swop?
I found a sweet 1992 Z28 with an auto... just wondering.
Old Jan 2, 2007 | 11:34 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
If all else fails go ahead and buy an automatic and get the petal setup from a junk yard car, also the clutch assy of course, you should be able to bolt the pedals right in, you need to cut a hole in the tunnel and be sure to grab the console equipment for the shirter boot, use the lower boot as a reference to cut the hole, you will need to secure the column lock switch so it will no longer lock the wheels, everything should line up together with the old products if you use the t5 transmission and bellhousing, be sure to get the correct flywheel.
HTH
i am sure others will be able to elaborate more.
Old Jan 3, 2007 | 06:11 AM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
you can do it for under 1g and it isnt that hard of a project.
Old Jan 9, 2007 | 10:39 PM
Fast89T/A's Avatar
Car: 1986 Chevy camaro Z28
Engine: 305 tpi
Transmission: TH-700R4
Axle/Gears: 2.73 posi
Hi, I was wondering, I have an 89 trans am with the 700R4 trans and i have a 96 firebird with the T-5. Would the 5-spd out of my 96 be the same as the one out of the 82-92 cars? If so could i use that pedal assembly and slave cylinder, clutch lines. I know i would have to get a new clutch but just wonderin. Thanks
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
86CamaroDan
Sep 29, 2015 10:08 PM
angel2794
Sep 8, 2015 06:22 PM
