Stupid TV Cable!!!
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Stupid TV Cable!!!
How in the hell do I get this off? I can get a socket on to the bolt but the rachet will not fit due to the side of the housing. Any ideas???
Axle/Gears: '01 3.42 10 bolt
put a jack under your crossmember. then unbolt the crossmember. lower the jack. this will give much needed room to work. another thing a have found works better than a ratchet is a regular 10mm wrench or a 10mm gear wrench for getting the bolt out. as far as getting the cable on and off the hook for the valve, that can be tricky and requires patience.
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
