t56 swap
Old Jan 8, 2007 | 10:59 PM
85T/A's Avatar
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
t56 swap
wanna do a t56 swap but dont know what i need and how to do it... any help greatly appreciated
Old Jan 8, 2007 | 11:05 PM
TexasLT1's Avatar
Car: '92 RS
pleeeeaaase do a search. you have no idea how many times this exact question has been posted and answered.
trans, bellhousing, flywheel, clutch, shifter, new crossmember, slave cylinder, notched trans tunnel
Old Jan 10, 2007 | 09:41 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
you also have to change the master cylinder too, right>?
Old Jan 11, 2007 | 03:12 PM
Pat Hall's Avatar
Master cylinder is the same. The line running to the slave cylinder and the slave cylinder itself are a bit different, but either a third or fourth gen master cylinder will work.
Old Jan 16, 2007 | 05:42 PM
jayk2k3's Avatar
Car: 85 camaro z28
the thirdgen line will work?
Old Jan 16, 2007 | 05:56 PM
dyrt's Avatar
Car: 86 Regal Limited
Engine: 95 cop lt1
Transmission: t56
Axle/Gears: 8.5" gn/3.73 gears
the third gen line is not as good as the 4th gen as the 4th gen is braided stainless. it is a good idea to just use a 4th gen setup though, as said above, either will work. This swap has had VERY extensive coverage, do a search for t56 swap and you'll get all the info you need. good luck!
Old Jan 16, 2007 | 07:55 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
When I did my T56 swap I did not have to notch the trans tunnel.
Old Jan 17, 2007 | 04:14 AM
Pat Hall's Avatar
I've heard that the thirdgen line is too short to work with a T56 setup. Besides, as stated above, the braided stainless fourth gen line is leagues better than the el cheapo third gen plastic one anyways.
Old Jan 17, 2007 | 07:25 AM
The slave cyl in a T-5 setup is on the front side of its bracket thing on the BH, with the line fitting about even, front-to-rear, with the rear surface of the oil pan.
The slave cyl in a T-56 mounts to the rear of its place on the BH, turned around "backwards" compared to how it mounts in a T-5, with the line fitting about 8-10" rearward of where the T-5 fitting is. The T-5 line consequently is about that much too short, to reach all the way back there.
The cylinder itself might work; after all, it's just a hydraulic cylinder, and does the exact same thing, so if the mounting is the same and the push rod is the same, then lengthening the line should in theroy work. Whether there's actually a practical and reliable way to do that, I don't know. When I did my T-56 install I just bought a whole new hydraulic system from GM and stuck it on, didn't pay too much attention to difference details.
Old Jan 17, 2007 | 07:54 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you know,
there are entire FAQs on this subject.... but some genius decided to make a FAQ board and put them all there... so instead of directing you to a sticky at the top of the trans/drivetrain board, im just going to tell you to do a search.
Old Jan 17, 2007 | 04:09 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Have you asked to get it moved?, seems like it would do a lot better on the top of this forum...
Old Jan 18, 2007 | 08:16 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
i got yelled at awhile ago for arguing about it.
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
