flywheel
Old Jan 24, 2007 | 03:27 AM
mr iroc's Avatar
Car: 88 iroc
Transmission: 5 speed
Axle/Gears: dount know
flywheel
i have a 88 iroc puting a 383 in it is im looking at a 15lbs flywheel from summit but is that to light for my car plans 4 the car is to be turned into a mean steet car if this is to light what whould u sugest
Old Jan 24, 2007 | 03:39 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
if you are gonna be racing it with drag radials or slicks, it will be way too light.. you need the added rotational mass for high-rpm clutch dumps.. those are good for road racing, where you dont need to accelerate from a dead stop.. it will take away some "streetability" because it will allow your motor to rev-up really fast and just be hard to drive everyday.. just stick with the steel.. or if you can find something with around 30lbs, thats a good compromise.. just remember to have it balanced with the rotating assembly
Old Jan 24, 2007 | 05:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I disagree. I'm running the GM lightweight flywheel for everyday use (no strip) without difficulties.
JamesC
Old Jan 24, 2007 | 10:16 AM
5678TA's Avatar
Car: 1984 Trans Am
JamesC
well there you have it.. street useage.. no strip.. i meant to say, "correct me if i'm wrong" somewhere in my post but whatevers.. all the old-timers at the track say i need a heavy flywheel to launch a heavy car at part throttle on slicks.. or it just makes it easier and more consistant than having less inertia and the engine bogging down and leaving at different rpms.. i have a 3step now so it shouldnt really matter.. pedal is gonna be to the floor anyway..
Old Jan 24, 2007 | 10:24 AM
Rule of thumb:
smaller motor, heavier car, highway gear, more traction, softer suspension setup = heavier flywheel
Bigger motor, lighter car, higher-# gear, less tire, harder tire hit = lighter flywheel
There's no ONE right answer. It's a tuning thing. Kind of like the people that post "what jets should I run".... you should run whatever makes YOUR COMBO work better. The guy in the other lane probably needs to run something completely else.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
