Flexplate
Old Jan 28, 2007 | 05:50 PM
G-Ride14's Avatar
Car: 1988 GTA
Transmission: 700-R4
Axle/Gears: 9-Bolt 3.27
Flexplate
My starter went out on the gta, so I bought a GMPP mini-starter from summit and in the process of taking it out I looked at the flexplate and saw that most of the teeth on one side were all chewed up. So now I need a new flexplate but I don't know what size to get a 153 or a 168 tooth?
Old Jan 30, 2007 | 06:03 PM
tpi355's Avatar
Car: 86' IROC-Z/03' Silverado Z-71
Engine: 355TPI/ 5.3 Ltr.
Transmission: 700R-4/ 4L65E
Axle/Gears: 7.5 in.-3.73 POSI
about your flywheel
First off, if your starter can be used with the 168 tooth flywheel get it because its way easier to find[ for future reference], second and most important, if your engine is a one piece, or "full circle" rear main seal you have to get a balanced flexplate, 1988 should be full circle rear main. If you don't use the right flywheel it will throw your engine out of balance and wear your crank bearings out real quick, not to mention the vibration would be unbearable. the one I used in my car is TCI part# TCI399773. If your two piece rear main seal then you can use TCI399273, these are both dual bolt pattern so any converter will bolt to them, I got mine from summit racing. Hope this helps ya out
Old Jan 30, 2007 | 06:45 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
I might have one for ya. let me know what you need and I will check my shop.
Old Feb 3, 2007 | 04:29 AM
Pat Hall's Avatar
Your flexplate is the 153 tooth version. If you just want a bone stock, no-frills replacement flexplate, they're dirt cheap (usually about $35-$45). An SFI approved racing style one will cost 2-3 times as much.
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
