how many splines?? 89 maro
Car: 89rs
Engine: 350 tbi
Transmission: stock
how many splines are the rear axles in a 89 camaro rs. its the stcok borg warner 10 bolt mini or whatever. ive searched and cant figure it out.. HELP!!!
Little confused on whats under the car. You have a stock 10-bolt and not BW diff. In most cases you have a Atuo with a 2:73 ratio and since 1989 was the changeover, My guess is youstill have 26 spline axle shafts. Reason: GM had a lot of 10-bolt 2:73 ratos with 26 spline axles in the inventory to use up.
Or pull a axle shaft and count the splines.
codeysabatini
Nov 10, 2015 04:07 PM
Prodigious
Sep 18, 2015 05:23 AM
