Mechanical Linkage...HELP!
Old Feb 16, 2007 | 07:55 PM
Quasi-Traction's Avatar
Car: 1986 Camaro Berlinetta
Engine: 4 bolt 355ci
Transmission: Borg Warner T-5
Axle/Gears: 3.73 Posi Disc Rear
Does anyone know a resource with a large scale diagram or exploded view of how the Mechanical linkage on the 82-83 cars is supposed to sit?
I'm having trouble determining the way one bracket is supposed to face, and my Chilton manual is too blurry and small to see enough detail.
Old Feb 19, 2007 | 01:57 AM
Pat Hall's Avatar
If you're referring to the z-bar, or bellcrank bracket, there should be pre-existing holes in the frame rail that line up with the holes in the bracket.
Old Feb 19, 2007 | 12:40 PM
Pat,
No, it was another bracket that goes between that one and the pivot stud on the Z Bar. Either way, I finally tracked down an exploded view from a GM shop manual online to see the correct way to put it in. Everything is installed now.
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
