tail shaft queastion
Old Feb 19, 2007 | 04:11 PM
saliger64504's Avatar
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
im putting in a th350 into my cat its a long tail shaft will i beable to use the tailshaft off my 700r4 so i can bolt up my torque arm i also have the hurst swap kit
Old Feb 20, 2007 | 11:08 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
do you mean the tailshaft housing ?
no
will not bolt to the 350 case
bolt are not same distance from 350 to 700
you will have to buy the aftermarket bracket kit
3rdgenparts
May 21, 2016 11:50 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
