LT1 T56 Hydraulic lines
Old Feb 19, 2007 | 07:36 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Well maybe this has been covered, but if it hasn't It should probably be a T56 sticky.
I purchased a supposedly ready to go T56 from a member on the boards. For the most part everything was there except the line from the master to the slave. The master and slave were nice too, because they were aluminum, so I did not really want to buy a new setup. Well I have looked everywhere, and finding a replacement line is a tricky proposition. Here is what I came up with after reading through some different web sites and magazines
Mcleod makes a fitting that has the stock quick connect on one side and -4AN on the other. The Summit part number is the following
MCL-139026
The -4AN works good because that happens to match up to a pre made Earle's Brake line. My car needed about 24 inches to route it safely. Here is the Summit part number
EAR-64191924ERL
Its not cheap, but it gets the job done, and is cheaper than buying a whole new assembly.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
