megashifter question
Old Mar 3, 2007 | 02:23 PM
bfox88's Avatar
Car: 90 IROC-Z
i'm just about done my megashifter install, i think i have a problem though. everything is finished its just now thati conected the shifter cable to the shifter i can not get the shifter to move or the shift lever on the trans. the car is turned on but the battery is not hooked up. not sure if this makes a difference or not. if anyone has any idea what im talking about i'd appreciate a reply asap.
thanks, brandon
Old Mar 3, 2007 | 06:06 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
no it shouldnt not as long as the key is in the on position, do u have the cable hooked up correctly to the shifter?and the trans? did u hook up the right cable? there is one cable that ur not suppose to use and if u hooked up that cable then it wont work. do u know that u have to pull the T trigger up to shift outa park?lol sry just making sure, maybe the cable is snagged or binding. not sure i understand the prob tho
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
