open dif. w/ drums to 3.42 posi w/ disc
Car: 1986 Z28
Engine: lg-4 305 carb.
Axle/Gears: 4th gen. 3.42 posi
I am about to swap a 3.42 posi w/ disc brakes from a 95 trans am to replace the stock drum open rear in my 86' z28. While I am doing the swap is there anything other upgrade or maintainence i should do in the processes? Any common problems with this swap? I have read the tech article on installing a wilwood proprotion valve, and the article on the 4th gen rear swap.
Is an aluminum drive shaft worth investing?
Abubaca
Sep 20, 2015 09:35 PM
Numbah-1
Sep 12, 2015 08:57 PM
