have a V6/5speed car, swapping in a V8, will the trans work with the new motor?
Old Mar 18, 2007 | 03:56 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
tried a search, didnt come up with anything
i have an 86' firebird that was originally a V6/5speed car. the original motor is gone, and i have a complete LB9 305 waiting to get swapped in. will the V6 5speed trans bolt up to the V8 or would i have to change the bellhousing? will all the hydraulics work also? if not, what would have to be changed?
thanks in advance
Old Mar 18, 2007 | 04:04 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
I think the input shaft on the V6 trans is different from the one used with a V8. Not really sure though.
Old Mar 18, 2007 | 07:03 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
All '83-'92 V6 T5s have a 14 spline input, all V8 F-body's have a 26 spline input, the '93 3.4L V6 also used a 26 spline input. They can be adapted.
Bolt hole patern in the bellhousing is different too, need to swap that with a V8 bellhousing. The V6 (2.8 and 3.1) engine is a 60 degree V, the V8 Engine is a 90 degree V.
Old Mar 18, 2007 | 07:20 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yep, the transmission itself is essentially the same. But the input shaft and bellhousing are different. But the swap is do-able.
Old Mar 18, 2007 | 08:58 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
so alls i need would be a V8 bellhousing? but id have to retain the V6 clutch/pressure plate setup, correct? what about the flywheel?
and does anyone know if the hydraulics are the same? would the V6 slave cylinder work?
Old Mar 19, 2007 | 01:41 AM
Pat Hall's Avatar
The V6 hydraulics are identical to the V8 setup. The biggest problem with this swap is the V6 clutch setup is too weak for a V8, and very prone to excessive slippage when used with a V8. The gear ratios in the V6 trans are also less than ideal for use behind a V8. They have a really steep first gear, and the rest of the gears have a really wide ratio spread. It's a totally doable swap, but less than ideal. You'd be WAY happier with a V8 T5. As far as the flywheel, I'm almost sure you'll have to use a V8 one. I don't think the bolt pattern is the same on the V6 one.
Old Mar 19, 2007 | 02:16 AM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
in the future, i plan on replacing the V6 trans with something more durable. unfortunatly, for now though, money is an issue and i have to stick with the V6 trans until some extra cash comes my way. cool thing about that though, is alls id have to buy is the trans and a new clutch assembly cause the bellhousing, flywheel, hydraulics, etc would already be in place
thanks for all your help guys, looks like ill be doing this swap sometime in the next few weeks
Jake_92RS
Jan 28, 2020 10:37 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
