rear end question
Old Mar 18, 2007 | 04:05 PM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
rear end question
hey man i have an 89 camaro convertible and was wondering what size rearend it is. it is a stock non limited slip rearend with 2.73 gears...is that a 7.5 rear end or a 7.58?
Old Mar 18, 2007 | 04:07 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
7.5 7.625 same
good luck
Old Mar 19, 2007 | 09:06 PM
irocz286's Avatar
Car: 1986 Camaro IROC-Z
Engine: 355ci, AFR Eliminator Heads etc...
Transmission: 700R4 Woooorked
Axle/Gears: 3:42 with Eaton LSD
I've got a 86 z with 2.73's being a 2 series carrier with 26 spline axles, if i get a 3 series carrier with 28 spline axles can i swap my 26 spline side and spider gears into it?
Old Mar 21, 2007 | 03:22 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
Re: rear end question
if its the same axle then yes, swap the carrier and shafts and all, everything
hope you hvae the tools needed to set backlash and also gear tooth pattern, includiung an dial indicator and gear marking compound, and an assortment of shim thicknesses too,
good luck
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
