shift kit
Old Mar 28, 2007 | 09:27 PM
bigal's1991's Avatar
Car: 1991 camaro RS
Engine: currently swapping 5.3
Transmission: 4l60e
Axle/Gears: soon to be 4:11
shift kit
ill a 700R4 stand up if i put a shift kit in it? or do i need to beef up the tranny?..... i have a 305, exhulst, chip, air intake, nothing very powerful
Old Mar 29, 2007 | 06:33 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: shift kit
i recomend transgo as will most of this board. as far as if it will last...that depends on the current condition of your tranny.
Old Mar 29, 2007 | 07:54 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: shift kit
It will give it nice crisp shifting and depending on wha shift kit you get you might be able to up and down shift at any rpm. I had a transgo in mine when it had the 305 in it and it would shift so hard the *** end would kick out sideways. I had to put in some new control arms.
Old Mar 29, 2007 | 10:09 AM
Shagwell's Avatar
Car: projects.......
Re: shift kit
Transgo or Superior, stay away from the cheapies like B&M if you want to give it a chance. As for whether or not it will last...as stated, depends on the current condition of the trans.
- you deffinitely don't want a shift that breaks the tires loose....
Old Mar 29, 2007 | 12:49 PM
Drac0nic's Avatar
Re: shift kit
I installed the Transgo HD kit, a vette servo and .5 boost valve it actually seemed to tame the shifts some as crazy as it sounds. When I drilled my sep plate I did as close to the "center" of the ranges as I could, if I was going to do it again I'd probably go more aggressive. I may also check the ATSG book I have and custom tailor my shifts that way. They are brief but not violent, which is fine by me.
Old Apr 1, 2007 | 02:10 AM
Pro Built Automatics's Avatar
Re: shift kit
"They are brief but not violent" That is exactly what you want!!! When done right, you can have smooth part throttle shifts, and the shifts getting firmer with more throttle.
Old Apr 5, 2007 | 09:31 AM
Drac0nic's Avatar
Re: shift kit
Yes, I added Hy-gard however and it seems to have caused the shifts to be sluggish. Even though it doesn't seem that much more viscous it makes a big difference in how the trans behaves, as a whole I like it though, especially on the top end.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
