Flexplate/Starter Question
Old Mar 30, 2007 | 08:22 PM
badcompany's Avatar
Hi guys.I have a 5.0l 305 out of a 1991 RS Camaro in my wifes 1976 Camaro.The 91 RS was a 5 speed car.I went to the salvage yard and got a flexplate to replace the flywheel of the standard because I am using a turbo 350 tranny.The guy that I bought it from said that all the "ONE PEICE seal motors had the same flywheel so he sold me one off of a 350 truck engine.I also went to the local parts store and bought a small starter for a 1998 Chevy Tahoe with a 350.Well the car starts fine but I have a vibration that was not in the engine when it was in the 91 RS.Replaced U joints to make sure.No better.New tires.It even seems like a main is trying to rattle a lil because of vibration.IS IT THE FLEXPLATE?Can the 305 and the 350 share the same flexplate?I know the one on the car has a weight on it.ANY HELP would be greatly apreciated. THANKS
Old Mar 30, 2007 | 08:51 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Flexplate/Starter Question
some have a weight and some dont
its kind of complicated, this subject has been discussed a million times in this board,
in 86 they moved the extra iron from the 85 and older rear crank end to the flexplate, this is why 86 and up are different plus the bolt pattern changed too and it wouldnt swap anyways
in one recent thread i posted links to pages with this info i dont know where it is now ill try and find it
Old Mar 30, 2007 | 10:10 PM
badcompany's Avatar
Thanks for the reply Randy.Could it be the wrong one?I sure hope its causing the vibration.If not I am whipped.Do I need to get a flywheel for a 1991 Camaro RS TBI? THAnks again
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
