Need to add fluid to a T-5 (Any tips?)
Old Apr 19, 2007 | 04:59 PM
Bowtie-Bri's Avatar
Car: I have a 70 Chevelle SS, and I have an 87 Iroc Z that I just brought back too life!
Engine: 305TPI
Hey Guys,
I need to add some fluid to the Borg-Warner T-5 in my Iroc.
Any ideas or tips for the best method?
Thanks in advance for your help!
Brian
Old Apr 19, 2007 | 05:07 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
Re: Need to add fluid to a T-5 (Any tips?)
the best and easyest way is to get one of the caps off a rear end fluid bottle the ones with the hose comeing off it. i think the sell the cap itself too.
open the top plug and tip bottle of fluid in.
after that put your finger in the hole and see if you can feal the fluid.
Old Apr 19, 2007 | 06:26 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Ive always just used a small hand pump, with thick differential fluid it can take awhile and get aggrivating but with tranny fluid its fine. I know a lot of people take the center console boot off then remove the shifter and dump it in there but that definently takes me longer time. Running a hose to the top ive never tried seems like it might get messy that way.
Old Apr 19, 2007 | 06:34 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
imo the best way is to just remove the uppper drain plug and fill it through the shifter, makes life alot easier and no need to lift it in the air
Old Apr 19, 2007 | 08:07 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
through the shifter.. pop that sucker off and pour away..
Old Apr 20, 2007 | 07:18 AM
Bowtie-Bri's Avatar
Engine: 305TPI
Guys!
One more question. How many quarts does it usally take to fill it when its empty?
Brian
Old Apr 20, 2007 | 11:38 AM
5678TA's Avatar
Car: 1984 Trans Am
my g-force t-5 took 2-3/4 quarts.. but i the standard is 2.5ish.. quarts that is..
Zane Story
Oct 8, 2015 12:40 PM
Stryker412
Sep 20, 2015 06:59 PM
Numbah-1
Sep 12, 2015 08:57 PM
DARKmj16
Sep 9, 2015 04:07 PM
