The checklist for swapping in this rear?
Old Apr 20, 2007 | 12:37 AM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
So i got a deal on a posi, disc rearend outta a 91Z its got 3.42 gears which i am going to keep through the summer and try out, may go up to a 3.73 but i figure jumping from a 2.73 imm alike these 3.42's question is, i know i need to do the seals but do i have everything else down?
1.I have the parking brake cables, will these just slip in where mine were?
2.Do i just get a master cylinder for a 91Z with a disc posi rearend?
3.Know i gotta do the proportioning valve, is a stock 91Z one fine?
I'm going to blast it and paint it probaly paint or polish the calipers and clean up the rotors till i can afford the big brakes, i'm on a tight budget right now so cheaper the better, i want to down the road beef it up and install bigger gears but i'll run it like it is now, thanks gents
and btw whats it cost to get a set of tires mounted nowadays? I got some old ones i think i'll say goodbye goodyears to and ship em to tire heaven
Old Apr 20, 2007 | 01:06 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: The checklist for swapping in this rear?
brake cables should be fine, master cylinder should be fine.. dont know about the proportioning valve.. mounting tires shouldnt cost more then $25 a pop..
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
