2.93 rear axle # of drive teeth?
Old May 1, 2007 | 07:28 PM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
Transmission: Turbo 350
Axle/Gears: Stock 2.93
I'm trying to get my speedo working properly as it's about 20-25mph off (higher) than where it should be. I have an '82 TA w/ a turbo350 tranny, chevy 350 engine, stock 2.93 rear axle & p215/65r/15 tires (26" diameter). I've seen the dfferent formula's to figure out which gear I need to get my speedo accurate, but need the # of drive teeth? Any help?
Old May 1, 2007 | 11:58 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 2.93 rear axle # of drive teeth?
I have never heard of a stock 2.93 rear axle. They're either 2.73 or 3.08.
This thread will help you with those two choices:
https://www.thirdgen.org/forums/tran...eedo-gear.html
Old May 2, 2007 | 07:11 AM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
Confirmed the rear axle number with a Pontiac dealership & one other well-known 3rd gen TA restorer. The code inscripted on the front, passenger side axle is 2PXC1042. Rear code (PX) says I have a 2.93. PZ would have been a 3.23.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
draco
Oct 4, 2015 09:25 PM
red90IROCls1
Aug 25, 2015 06:56 AM
