Transmission Identification
Old May 12, 2007 | 06:51 PM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
This is the story. I just pulled a transmission from a 1986 van. The engine was a V6, externally balanced flex plate, with center bolt valve covers and the transmission looks to be a TH400. The trans pan looks like a 400. It has a vaccum modulator and a one spade plug-in on the side. It has a 6 bolt hex pattern for the tailhousing. But here's where I get confused, the tailhousing is 9" long, overall length is just under 35" , the slip yoke is a slip on with 27 splines. It isn't stamped TH375 on the underside of the tailhousing either. I can't find any id numbers on it. The pan has Turbohydramatic, Division of GM stamped on the bottom. The bellhousing has HD 42 on it and that's it. Help would be appreciated.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
