Transmission HELP!!
Old May 12, 2007 | 10:08 PM
MMX17's Avatar
Transmission HELP!!
My transmission seems to be slipping or going into overdrive by itself. I have a 1991 Camaro RS V8 5.0 Automatic. The tranny started to mess up after I fixed a short circuit inside the car which would make the gauges not work. I also fixed a white switch that has something to do with the brake. Its a switch that is visible before the high beam switch and there is one just like it next to it. I'm guessing it was that but I don't even know what the switch does.
Old May 13, 2007 | 07:09 AM
Silver87's Avatar
Car: 87 T/A
Engine: 305 4BBL
Transmission: 700R
Re: Transmission HELP!!
Sounds like you found and repaired the TCC switch. It is white and has a plunger that is operated by the brake pedal. I fixed mine and it took a little while to get used to the converter locking up like it's supposed to.
Old May 13, 2007 | 01:55 PM
MMX17's Avatar
Can I disconnect it, drive around and my tranny will be fine?
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
